RCU Forums - View Single Post - wing incidence
Old 08-09-2008 | 01:58 AM
  #38
flyX
Default RE: wing incidence
It'll also cliamb if the airlerons are set too high.
If you had thicker foam on the wing's saddle it'll change the wing's angle of course.
Since it's an ARF , I'd follow the instructions but you never kown.
I've glue the rear center section pieces upside down before, if you align the airleron to it , it's going to be off.
I notice it after using the airleron guage, of course
For the cowling.. I used left over berch spar pieces..It didn't look bad plus it gave a path for air to exit the cowling
