Twin Verticle Stabs
I was thinking about why the toe-in offset was specified.....I'm guessing to keep it tracking straight and true and a little extra for torque?
Trying to keep the fins at 90 degrees in every axis while the epoxy set was a real chore with my B-24. I used tape and a bit of CA to tack glue them in the correct position while the epoxy set.
Should be easier if you have a tight fit that is correctly aligned already....I didn't.
Love the Lancaster......how about some pictures?
H.
