RE: G26EI
You DO NOT have a problem. Tune the engine so that it runs proper and go fly. You'll get used to the silence when going down hill.
When diving at idle the prop is turning faster faster than the carb is set for. The fuel mix goes off and the sounds like its died, but as you see it comes back when things are balanced
