RCU Forums - View Single Post - How close is 'too close'??? RX battery placement question
Old 08-10-2008 | 08:00 AM
krproton's Avatar
krproton
Default RE: How close is 'too close'??? RX battery placement question
I am not sure if there is a consensus out there, but I think 10" to 12" distance between anything "engine - related" (engine, ignition switch, ignition module and ignition battery (if used) is the norm. I wouldn't ignore that unless you absolutely must (as apparently, in your case). I guess if it range checks (engine running at all rpm's) you might be okay.
