RCU Forums - View Single Post - Lateral Balance / Trim Problem
Old 08-10-2008 | 07:17 PM
combatpigg's Avatar
combatpigg
Default RE: Lateral Balance / Trim Problem
It's most likely what Steve said, time to double check the balance job.
If the wing has a twist, you will be able to see it with a trained eye from well behind the plane, at eye level. Most .40 sized planes can be eyeballed [for a twist or warp] at arms' length.
