RCU Forums - View Single Post - Pull Pull system with cable housing, ok/bad?
Old 08-10-2008 | 10:09 PM
Magna
Default Pull Pull system with cable housing, ok/bad?
Hi all
As I'm about to build my Excelleron 90, its come with pull pull for rudder and elevator.
The housing for the cable routing has been provided for all the pull pull setup (2 for rudder and 4 for elevator due to the split)
While I will pay attention to the ackerman etc during assembly, I want to know if the cable inside the nylon housing is an issue in affecting the operation and the angle/setup?
The nylon housing will rub at certan angle as the moving surface deflect. Although the elevator will deflect max at about 1.5cm or half in. The rudder is more.
There is no way for me to bypass the housing without major butchering the frame.
