RCU Forums - View Single Post - Engine run on ....
Old 08-11-2008 | 01:49 PM
djmarch
Default RE: Engine run on ....
I checked the idle stop screw as you suggested and it appears it may have been slightly open (almost undetectable). I let it out 1/8 th turn and will see at the field what happens.
Thanks for your suggestion. I had already let it out but did not adjust any further thinking it was closed enough.
You probably have it spot on.
thanks and will advise
