RCU Forums - View Single Post - Another Blue Angel build
Old 08-11-2008 | 08:35 PM
  #68
crankpin
My Feedback: (15)
Default RE: Another Blue Angel build
You can use Dave Brown Pushrod's. They are fiberglas, and the ends come in single or double. You can squeeze 4:40 rods in, with a little mod. Getting two 4:40's in for split elevator's will work, if you use that size.
The thread way works fine, used to use that with 3/8' sq. stock. I just looked up at your set-up. Did not realize you were using the long rods. If it works, don't fix it.
Crank
ID:	1009277   Click image for larger version
ID:	1009278   Click image for larger version
ID:	1009279   Click image for larger version
