RCU Forums - View Single Post - Engine run on ....
Old 08-11-2008 | 10:05 PM
krproton's Avatar
krproton
Default RE: Engine run on ....
Most guys completely remove that tapered "stop" screw altogether. Also, sometimes engines will "run on" if they're hot (lean) on the low end needle. But I bet you solved it when you backed out the screw jsut "that much more." I bet she quits when you get to the field tomorrow (when you lower the throttle stick all the way!).
Good luck.
Tim
