RE: supertigre 51 problem
Pull the needle valve out and put your finger over the muffler outlet and crank it over with a electric starter. That way it will flush out any thing that might be in the carb. When you crank it over you see almost a steady flow of fuel coming out of the needle valve hole. Just a thought.
