RCU Forums - View Single Post - "Don't forget Stihl"
Old 08-13-2008 | 08:51 AM
frenchie79
Default RE: "Don't forget Stihl"
I'm putting EI on this Stihl. This is a 24cc that i thought would make a great motor. Very light, Dual rings, Large ports. Cut the center of the flywheel which gives me the tapered and "Keyed" section for a solid base for prop hub and a base for the adjustable timing collar. I tapered a peice of 1/2" Ali to match the crank taper-chucked that in the Lathe and trued it up. Also made the prop hub.
Added the pix with the adjustable collar for timing.
ID:	1010550   Click image for larger version
ID:	1010551   Click image for larger version
ID:	1010552   Click image for larger version
