RCU Forums - View Single Post - axe cp thread
Old 08-13-2008 | 11:43 AM
  #1884
gfisher99
Default RE: axe cp thread
Is the driver you are using roughly the size of the Inside Diameter of the bearing hole in the grip? I think my problem was that the torx driver I was using fit snugly inside the inside collar of the bearing, and then when I applied pressure, it popped that inside collar out of the bearing.
