RE: Sig Smith Miniplane build
Tiffoso,
Posting pictures, on the upper right corner of this exact post you will see a reply button. If you click on that, you will see an option to upload pictures on the lower left of your typing area. Click on that and follow the instructions. There are other ways as well but that is generally the easiest.
Another landing gear tip. I am sure you know this already with two other tail draggers. Anyway, if you have a little bit of toe-in(front of tires slightly pointing at each other) on your main wheels it will help a little bit with tracking.
Having the landing gear just bare wires is not a problem. Mine has been that way since it was built. Most recent pictures are on post 179 above.
Good luck, you'll have a blast with this thing and the Brazilian Skys will love it as well.
