RCU Forums - View Single Post - Setting my Idle up...Help!
Old 08-13-2008 | 09:25 PM
brrzee
Default RE: Setting my Idle up...Help!
Mobyal that is the exact setup I have in my plane. Will take your advice on setting the trim all the way to the low position. I think when I first set it up I left my trim at the half position which it was factory set that way. I will redo it and see what happens, if not I was told to look at possibly adjusting my low speed needle valve to have it run better at about 1/4 throttle or so.
Thanks for the tip
