RE: Does anyone else have this problem?
Spur gears kept burning out on mine because my chassis had cracked and my engine was slightly tilted. A couple washers under the engine mount screws fixed that. Just make sure the gears are meshed right and that the spur gear is parallel with the engine gear. The plastic gears can burn out in literally minutes if they aren't meshed right.
