RE: Setting my Idle up...Help!
One of the beauties of using comp radios is being able to set things up electronically and not so much mechanical tinkering. I would suggest taking the time to read the manual and setting the end points before adjusting the low end needle.
I don't have the DX7 but most radios use ATV and then select channel 3 for the throttle.
Good luck.
