ORIGINAL: mrdhud
Stickbuilder
Bill,
Your cowl & dummy engine looks real good I couldn’t tell did you use the stock muffler and what size prop are you using? I’m getting real close to start covering I have all flying wires installed and struts built now I have to repair all the sheeting I had to remove installing wires & struts. I will post some pic before taking her apart.
To all
Let’s all get together and PM Bill with a tee shirt order I still have two from the first batch these are hi quality shirts that you’ll be proud to wear.
Dan,
Yes, I went back to the stock muffler. I did need to modify the bottom front of the stock unit to be able to clear though. I bought a couple of different aftermarket mufflers, and may wind up using one of them. The prop is a Zinger 18X6 that will be finished as a scale unit. I have a spinner that was designed for the AT-6 to use on the model. The smaller one requires some trimming to clear this prop. I could have used an aluminum hub nut, but it does not look right, nor does the stock nut.
Bill, AMA 4720
WACO Brotherhood #1
