RCU Forums - View Single Post - RCGF Engines
Thread: RCGF Engines
Old 08-14-2008 | 09:25 PM
plasticman
My Feedback: (97)
Default RE: RCGF Engines
ORIGINAL: mmattockx
SunShyne,
From Henry's site:
Displacement (cc) 26cc
Bore x Stroke (mm) 1.33"x1.12" (34mmx28.6mm)
Carburetor Walbro
Ignition DC-CDI (electronic ignition system)
Power supply 4.8-6V
Weight - with ignition and muffler 39.6 ounces (1122g)
Weight - without ignition & muffler 34.4 ounces (975g)
Maximum Output 2.6hp/1.85KW
Speed range 1500-8000rpm
Gas/Oil Mix 25-40:1 (90 octane gasoline)
Propeller 18*8 7100 rpm
I added the bolding. Henry told me tested the 45cc with Xoar props, so I expect that is what the 26 got as well. It is not as strong as a good glow engine of the same size, but it is doing decent numbers.
Plasticman, you will have to buy one and tell us how it works out with the pipe. How's that other 26 and pipe working in your big Fusion?
Mark
Mark,
The the other 26 is back with the manufacturer for repair; don't expect to see it anytime soon. The big Fusion awaits power and this RCGF is a candidate and my ES Composite pipe is ready for a mate. I am hoping Piston can set me up. I will get some numbers, video, and post the results if this happens. No doubt, the 26 falls into that perfect O.S. 1.60 replacement if it can get into the 9000 range.
David
