CG Ultimate alternative cabane struts?
I am currently building the CG Ultimate and at the same time I scaled the design up 15% larger to get an Ultimate that has a 62 inch wing span.
For the larger Ultimate I contacted TNT the landing gear people and they bent up a set per my drawing. Its made of landing gear aluminum which is a lot stronger than the flat stock hardware store aluminum.
TNT will work with you if your interested and provide what you need.
tonyc
