RCU Forums - View Single Post - Another Blue Angel build
Old 08-15-2008 | 03:26 PM
  #75
dhal22
Default RE: Another Blue Angel build
rear stab sheeting is underway. i sanded the sheets smooth before i glued them this time. last time i wasn't happy with the grain patterns showing through the fiberglass cloth and polycrilic. i like to use a polyurethane glue to assemble the foam cores and balsa sheeting. i use a 6" foam roller and put just enough glue on the foam to see a shine to it. you can roll the glue around until it shines. after assembly i clamp firmly with ply pieces and clamps. the polyurethane is extremely strong and only a very little is needed.
david
ID:	1012127   Click image for larger version
ID:	1012128   Click image for larger version
ID:	1012129   Click image for larger version
