RCU Forums - View Single Post - Prop continues to fall off
Old 08-15-2008 | 04:11 PM
jetmech05
Default RE: Prop continues to fall off
wood props sre hard to tighten simply due to humidty causing the wood to swell....then shrink when it's a little drier and the nut is loose....switch to APC and tighten it down to where the prop leaves a mark in your hand.....I've seen lots of wood props loosen but rarely a plastic/glass prop
