have to return Easy Glider!
Step 4: Glueing the tail assembly to the fuselage:
As I site down the fuselage I can see that there is a bend in the last 5" at the tail end.
The tail assembly will mount crooked to the longitudinal axis.
I have not mounted the tail section yet.
If I put a straight edge on the fuselage where the tail should mount and follow it to the nose I can see the angle is off by 1.5" at the nose of the plane.
I think this is unaceptable? I could attempt to twist the tail when I assemble it but it wont be fitting properly to the fuselage tabs.
I could compensate when adjusting the rudder?
I wonder what their solution will be?
I want a new straight fuselage...
back to the LHS in the am.
Steve
