Antenae Wire Length
murph,
Looping it inside the fuse isn't a good idea. You want that antenna stretched out.
Usual way to handle it, is to drill a small hole in the top of the fuse behind the wing and run the wire through it to the top of the vertical stab.
Do a search on mounting antenna wires. There was a good one a few days ago with illustrations showing how to do this.
Dennis-
