RCU Forums - View Single Post - clutch bell setup
Old 08-16-2008 | 01:21 PM
AllAboutFunHobbies's Avatar
AllAboutFunHobbies
Default RE: clutch bell setup
Your missing washers or center spacer. You space the clutch bell by putting washers on the inside of the clutch bell on the pilot shaft. You can take the clutch bell and pilot shaft to the local hardware store, not homedepot or lowes needs to be a place like Ace hardware, and find some washers that will fit the pilot shaft and fit inside the clutch bell in the bearing area.
