4 stroke throttle barrel came off
OK, the screw that holds the throttle barrel came off. This is the screw that moves inside the groove in the throttle barrel, that limits the movement of the barrel.
Now I put back the screw and the barrel movement is perfect, mounted the engine cowl etc. Just realized that i forgot to put back the spring inside the barrel.....is it sooo important? I will have to re open everything!! There is hardly any play in/out on the barrel.....do I still need to re install the spring???
Cheers
