RE: KMP Beaver: Just started, looking for feedback
Hi Noah,
That would be marvellous if you could do some more pictures please, especially the rudder set up and mounting position.
The positioning of the Ernest rudder mounts has me a little stumped, I have figured out that I will have to trim them some of the front part of the rudder material. My intention is to steer them via the tail wheel using something like Dubro 4-40 size push-pull cable( or some coated fishing trace wire ). So I think I'll have to have the rudder control horns above the float deck height.
I will use the 247 for the back strut seeing as I will be making the middle four up... if anything I guess it'll just slightly decrease the float wing incidence some? How it you check the float step in relation to the 80mm CG at the wing?
Many thanks, Paul
