RCU Forums - View Single Post - AMA Pattern Max Voltage
Old 08-16-2008 | 05:08 PM
Troy Newman
Default RE: AMA Pattern Max Voltage
Tony,
The rule just passed by the AMA contest board limits the voltage to the 42V nominal just like F3A. This rule takes affect in january 2009. Current rule for AMA classes.... there is no rule on maximum voltage today. Until January 09' you could run a 12S system if you like. After january 09 this is no longer allowed.
I have some thoughts on another subject that deals with this one too.... Its found in the normal pattern forum as it really is not electric specific.
http://www.rcuniverse.com/forum/m_7853169/tm.htm
Troy Newman
