Dual Elevator
Thank you for your reply to an earlier post of mine, however I have a couple of more questions.
I have a 7CAP which is not 2.4. I am setting up a Balsa USA 1/3 scale Sopwith Pup. It has separate elevators and I am using separate servos (FS-34) for each elevator half. I can not get both servos to travel the same distance. I have tried adjusting the pull pull system to center the travel with out any success. I am using a Y harness for the servos.
Question: Would a Futabe MSA 10 multi servo adjuster work in this situation?
If I understand the instructions for the MSA 10 it will match travel and end point settings for 2,3 or 4 servos. Am I understanding this correctly?
Thank you in advance.
Fred
