RCU Forums - View Single Post - Magnum 30 Four-Stroke advise needed
Old 08-16-2008 | 06:16 PM
Kimhoff
My Feedback: (22)
Default RE: Magnum 30 Four-Stroke advise needed
Cool plane. You will never get the idle low enough to keep the plane from moving without some help. You will need to bind up the wheels with some fuel tubing and get some props that don't have any bite at low RPM's. Like the person said above these engines idle fast. You can put a onboard igniter on and help the problem also.
Small props with a tiny one on the front engine might work.
