RE: Telemaster 40 Rates?
Since you ask about rates I have to assume you're referring to dual rates? Otherwise perhaps you mean amount of throw,travel adjustment. If it's dual rates you're asking that is not a critical adjustment and can only be set bye guessing and flying. The total travel is generally given on the plans. This is a very gentle aircraft and if you don't feel capable of maiden flight let someone that is do so and any adjustments will be evident.
