The problem with glued joints anywhere is joint design. If a slip fit is too tight, there won't be any space left for a mass of glue to do its' thing. This is what makes the idea of using glue in control systems iffy. I use glue when making up carbon pushrods, solder just doesn't get 'er done then.
