RCU Forums - View Single Post - Magnum 30 Four-Stroke advise needed
Old 08-17-2008 | 08:48 PM
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Magnum 30 Four-Stroke advise needed
ORIGINAL: jrf
Thank you Patxipt. I will try your settings. I did not tach the idles I am getting, but I'm sure they are quite a bit higher than 2700. Maybe I should try 10x5 props instead of the 9x6's, to get the landing and taxiing speeds down.
Does anyone have a glow plug recommendation that works really well in the Magnum 30 FS?
Jim
They run very well with a 10x5 a 9x6 is a bit under proped. They will also run well with a 9 1/2x6.
