RE: threading 2-56 push rod
The threads on a 2-56 pushrod are "pressed" on, rather than cut like that tool would do. A normal 2-56 pushrod is slightly thinner than its threads. When the threads are pressed into the rod, it causes the metal to squeeze out into the threads. If you were to use the tap, the threads would have no teeth. It would work ok if the rod was slightly large to begin with.
