2-Stroke Engine Selection
The tower is a good engine. I have one and it is very reliable. If you are going with the Fx, you should get the .91. It is in the same case as the .61 and it is way more powerful. The .61 fx is the weak fx, even less powerful than the .65 la. You might want to try the magnum xls .91, almost identical to the O.S. It is around $150.
