RE: New Plane
in a 46 sized plane weight difference between standard and mini servos isn't a huge issue.... I was looking at 25-46, I would not put standard in a 25 either. I just have a bunch of hitec 5945's and 5625's and airwild 1 1/2 inch alum arms threaded for ball links i wouldve liked to use if possible but i know that takes a slightly larger plane to accommodate.
and if i get the eratix ( which i'm thinking of ) i definately want the 32 in it, I had a showtime 90 with a ys 110 but it wasn't enough power so i have a os 1.20 AX in it now which is way more but electrics can get such a better power to weight ratio that i would get the 32 i think to take advantage of that.
I would get the eratix
Power 32
Castle Creations Phoenix speed control for whatever amperage is required
hitec hs-225ms
ThunderPower or FlightPower 14.8v lipo
Thunder Power 610c balancing charger
