RCU Forums - View Single Post - Correct initial throttle setting
Old 08-18-2008 | 09:45 PM
carrellh's Avatar
carrellh
Default RE: Correct initial throttle setting
ORIGINAL: hawes99
I use a DX6i. There is a "Throttle Cut" button. So there is a way to program this button so that it will take the throttle from "almost" closed to fully closed?
On page 3 of your manual it directs you to page 41 for throttle cut. Read pages 41 and 42 and enable the function. Then turn on the receiver and see what it does.
You'll need to enable the function each time you add a new model to the memory since the function is inhibited by default when you set up a new model.
