RCU Forums - View Single Post - anyone using the BCMA 42-pro?
Old 08-18-2008 | 10:35 PM
soarrich's Avatar
soarrich
My Feedback: (98)
Default RE: anyone using the BCMA 42-pro?
ORIGINAL: djt294
believe it is most likely an MT-42. I think that BCMA just resells it .................. It is probably a good platform to learn
Yes, it's a MT42. I have one, so far I just test ran it to set the carb, runs well, does have that shake in lower rpms, but all single cylinder engines have shake most shake just above idle, this is a little higher, no problem. Mine is going in a Celmark S2 Pitts. Casting quality is very good seems to be well made, it started easy, tuned straight forward with out a problem. I ran mine with a 20x8, I wish I could tell you the rpms, but if I don't right it down right then I don't remember, getting old is a *****.
