RE: YAK 54 TOC1
That is the same rpms as i got, and i did hear the same thing bout the TBM props... First flight was at 18.8 lbs, then added ex battery and smoke tank, secound day was at 19 lbs, smoke pump was already installed for the first flight. I really noticed the 1/2 lb weight added. So I took out the smoke pump, battery, tank, and one of the battries for my rx. I droped the weight down to 17.5 lbs. havent flowen yet. I really wanted the smoke, so i thinking i might sell the DL to a buddy and get a evo 58. Im gunna do all i can to make the DL work first though. Cause I think that flying this plane at 17 lbs will be alot nicer than at 20 lbs.
