RCU Forums - View Single Post - J3 Cub - Flying technique
Old 08-19-2008 | 02:24 PM
TFF
Default RE: J3 Cub - Flying technique
Differential ailerons help with the adverse yaw. More up than down about 2 to 1. Mixing in the rudder to ailerons helps if you dont want to do it manually. I find that you have to lead with the rudder just a spot before you move the ailerons. It sounds like it is flying like the real thing though.
