cg question?
Flyfree,
I sounds to me like you're not understanding the relationship between CG (center of gravity) and CL (center of lift). CG is normally slightly forward of the aircraft's CL so that in the event of a stall the craft will nose over and achieve enough airspeed to have lift again. Placing the CG further aft will aid in aerobatic handling for certain types of manuveres, but at a price.
If you don't know where the center of lift for your aircraft is....
1) If you built from a kit, it will say on the plans.
2) you bought a plane pre-built and covered, CL is usually dead center to the main spar.
3) If you can't see the spar, a good guess would be 25% of the wing chord. The wing's chord is the distance from leading edge to trailing edge of the wing at the root (Part of wing closest to the fuselage).
Hope this helps
