RE: please help me build my first nitro plane!
Them guys are right about a high wing trainer plane. Then go to something else after learning the basics good. You will have a good idea of what your limitations are then and are apt. to get a better suited plane for your second one. And Nitro does not have the best track record for sending all of what you order or having instructions worth a darn. With the manufactures listed above you can call and someone will be there to help THEN. You don't have to wait six weeks to finally get someone to help if your having a problem. Nitro has cheap planes but there is a very good reason for it. Just look at the request topic here. That should tell u something if not then good luck you will need it.
