RCU Forums - View Single Post - Direction for 2 stroke glo engines
Old 08-20-2008 | 08:44 PM
HighPlains
Default RE: Direction for 2 stroke glo engines
some engines with rotating front bering cases can be rotated 180 degrees for reverse running. One of these engines would also require a reverse pitch prop normally used for a pusher aircraft but installed backwards from that application.
Better check again John. To make an engine with removable front end run backwards, you only turn the front end 90 degrees counter-clockwise.
