RE: Feei Bao F22 Raptor advise Please
We had no problems in normal flight, it has a very wide flight envelope. Although the camo grey makes it somewhat difficult to see, the configuration makes it easy to keep orientation in flight.
With limited aileron throw, we (my son and I) found it necessary to mix in some taileron with ailerons for control at low speeds. The mix could be turned on or off as needed. It took a bit of experimenting to get the mix % in an effective, but comfortable region. We started with a little bit, and added after each flight until it was exactly what was needed.
Simplicity is good, it will save a lot of expense, wiring, and weight
