RE: Saito 120 Trouble
Hi Edwin & Greybeard,
Thanks for your prompt responses! Edwin, in regards to fuel I use 10% 2 stroke fuel....not sure on castor content....I'll have to check. I think I might take engine off plane and put it on a test bench, I'll also clean the carb as you suggested. The engine is only a baby and had around 12 flights....basically still running in I suppose. I swapped this engine from the P47 because I didn't have the money at the time to purchase another saito. I put a 91FX into the p47, which performs beautifully!
Greybeard in response to your question, yes it is the pressure line, sorry.
Regards
Daz
