RE: Scaled Tiporare Plans
I couldnt find how much anhedral this plane needs on stab ? im building the 10 version and will use a MAGNUM 15 XLS-A .
Problem with 10 version fuse is width you cant use std servos unless they are one behind the others but thats lots of problems, im going to use four Hitec HS 55 servos, what should be the anhedral stab measure using std muffler, HOW MUCH DOWN ? degrees ? mm ? what should it be ?
Thanks for your help guys , im considering opening a building thread of this beautifull bird !!
Regards.
Rafa
