RE: Thoughts on Reactor Bipe?
Scalenut,
Two maiden flight suggestions... Watch the Aileron throw... Even the low rate is kinda high for a first flight... And the low rate on the elevator is a little soft you might want to consider a little more than recommend depending on your flying style...
Sorry to hear about the wing, at least is is the top one so you will be able to do a lot of assembly while waiting for the replacement..
Good Luck,
