RE: crashed airplane - engine question
Is it a new engine? On the ABC type engines the cylinder wall tapers ever so slightly, getting tighter at the top, so you get the most compression around TDC. On a new engine, it can be so tight that it seems to "stick" at the top. As the engine breaks in, the stickiness will go away.
