ORIGINAL: doxilia
Petec,
cool. Let us know if you start building a Mirare (40 Tipo).
120? Try the following on for size
http://www.4shared.com/file/59962337...n_-_66x40.html
Wing Span: 72.0"
Stab Span: 29.6"
Fuse Length: 63"
Fuse Width: 3" (internal at CG)
Spinner & Wheels: 2.50"
Retracts: Probably a nice set of Robarts
Weight: 9-10 lbs
Power: .90-1.20 (~1500W)
Wing Area & Wing Loading? Haven't figured them out yet.
Do you have some more details/specs/photos of the Prophecy?
David.
Thanks for the scaled up plans David. I need to get my Black Magics done as well as the DB40 that is on the bench before I start on the 60 sized Tipo let alone the 40 size, but it is certainly on my list of things to do. I figure it will be a good back up airframe for the DB40 if something were to happen to it or I might need to pick up another YS 45FR.....now there's a thought.
I do not have any particulars on the Prophecy since the one I had I bought used.
I think I can safely say I have enough planes to work on over the winter building season now.
Pete
