RCU Forums - View Single Post - Loaded Eurofighter build thread
Old 08-23-2008 | 03:34 AM
marc s's Avatar
marc s
Default RE: Loaded Eurofighter build thread
Fritz nice work as usual, great to see some pics of the air brake as well, I have the kit supplied for this so will be interested to see as many of these as possible.
OK sorted out the pipes, after a few mails and a conversation the supplier has agreed to re-make them so the exit nozzles are parallel to each other, should collect from Jetpower in 4 weeks time.
Have worked out and mounted (temporarily) the two 8411's to give the best overall linkage set up for the canards, just need to wait now for the mounting hubs for the canard shafts to arrive (see pic of 6.5mm version - supplied by Servocity who carry a great range of items for tackling all sorts of servo and linkage problems ) and I can complete the linkages. Still pondering over how to fix the front of this servo tray in the nose without removing a section to fit a fixing in - any ideas out there?
marc.
ID:	1017208   Click image for larger version
ID:	1017209   Click image for larger version
