RE: can this happen
If mode one is throtle and arielon right stick, rudder and elevator on left then yes......have tested all on ground all seems good I am flying tomorrow so will let you know. Have changed the rudder to pull pull system with hitec servo mounted over cg changed the back servo to dual elevator servo set up............... cheers
